what did i do wrong ? where is my problem?
76 camaro 3500 lbs
350 stock bottom end as far as i know it came with car and i rebuilt the top end 9.3:1 477/477 cam and 268/268 duration 1.94/1.5 heads edelbrok torker intake holley 750 (kind big) should make 300 hp atleast sounds like 350-400 th350 2000 stall 3.73 gears with m/t 29/12.5/15 sprotsman pros my problem is its a complete dog it wont spin the tires at all where should i look for my problem im not sure if trans and tourqe converter are good they cam with the car and we test drove it with the vaccum modulator not hooked up im not sure if this make a diffrence or not i know the tires are big but the motor sounds great rev's up nice im willing to change the gears and such to get me going just looking for suggestions but building another motor is out of the question im on a tight budget any help is appreciated thanks logan |
a loser convertor, say a 3200-3500 would help a lot and some deeper gears for sure
and a properly tuned 650 dp carb that all would help a lot |
deeper gears as in higher? i was looking at 4.56's or 4.88's it gonna be a street car mainly might take it to the track once in a while so im not worried about running out of rpm's at the big end
Since you did not build the bottom end, did you check the cam to make sure it was degreed right? Did you do a compression and leak down test? Have you verified the timing pointer? Just some stuff that can really kill power. It may not set the world on fire with what you have but you should at least be able so spin the tires.
The gears are fine just not ideal if just a race car. The carb is fine also just maybe not ideal. My 2 cents. Curtis |
whats the over all timing set at ? i think a 650 carb and 3000 or higher converter will help :wink:
Actually, the 4.56 and 4.88 gears are lower than the 3.73 :D |
i know there numerically high but actually lower
how should i degree the cam i just lined the dots up on the timing chain and put the cam
how should i go about degreeing the cam ive never done it before |
This is instructions on how to degree a cam. You will need the info on the cam to do it though.
http://www.cranecams.com/uploads/instructions/803.pdf |
| All times are GMT -8. The time now is 10:23 AM. |
