-   -   la billet crankshaft..SBC (https://www.racingjunk.com/forums/showthread.php?t=31286)
NOVA383ROLLER 11-23-2011 05:26 PM
Can anyone help me on a crankshaft that i picked up cant seem to find out what the stroke it is...numbers on crank is #16562 an on the front is h026687
482 11-23-2011 06:20 PM
You need to find centerline of the crank and then find the centerline of the journals. That should give you measurement in inches. That is the crank size.
One way is to use like a wood dowel that will fit in one of the journal center holes. Then measure from the center of the crank snout to the center of the dowel.
I think you would multiply crank measurement x 2 to figure piston travel.
OR
You could take it by any machine shop and they could tell you
NOVA383ROLLER 11-23-2011 07:45 PM
la billet crankshaft SBC
Thank you learned something new tonight..
NOVA383ROLLER 11-24-2011 02:17 PM
4.00 thanks
