Tranny Feedback
Well to make a long story Short I tore 1st,2nd and 3rd gear out of my 73 camaro Thanksgiving day showing my a$$..thank goodness I had 4th gear to get home.....the only thing I felt good about it is I think the tranny had a little something wrong with it anyhow cause it would come out of 3rd gear around 4500rpm
ok here is what I am kicking around..I have always been the type of Guy to be different with the Rides I have.. I have a chance at a great deal on a Richmond 6 speed !!!!!..about a $3500 tranny for the cost of a Richmond 4 speed ?....but here is my delima...the tranny is 3.28-2.14-1.57-1.24-1.00-.76(OD).....With the 373 gears it will be like a granny tractor in 1st gear..so I would almost be forced to change my rear gear ( Maybe a 3.08 ?) then I must buy another shifter and minor floor fabrication because this tranny sits about 2 inches further backward then the 4 speed...thats really No biggie since there is no console in the car. Now I have aired out my Cons......What are some thoughts on this idea ? you guys see many 6 speed straight drives in 2nd generation camaro's ? does the pro's outweigh the cons on this deal ? |
Go here and become a member, everything you need to know about 2ng gen Camaro's
http://www.nastyz28.com/forum/index.php Now from what I have read you will need a bellhousing, hydraulic clutch setup, crossmember, driveshaft and I think you might have to change the pinion angle just a hair. All the guys over there love their 5 and 6 speed converted Camaro's. If mine ever blows I will step up! |
http://www.nastyz28.com/forum/index.php Now from what I have read you will need a bellhousing, hydraulic clutch setup, crossmember, driveshaft and I think you might have to change the pinion angle just a hair. All the guys over there love their 5 and 6 speed converted Camaro's. If mine ever blows I will step up! daaaaaayyymm that puts it in a different shade of light for sure...wow ! |
Its not a cheap conversion but if you are buying the tranny cheap it will be worth the investment
Throw away the Muncie and put a iron case T10 in it and be done with it and more original. The Muncies were notorous for shelling gears, even in the day, due to case flex.
JMO Zip. |
t5
Not sure if this helps, but I put a mid 80's richmond 5 speed (T5) in my 70 chevelle BBC car,about 5 years ago, it came with a shifter, and it was a fine spline so it went into my clutch, pressure plate set up w/o any mods but the cross member did not line up and I fab'ed a mount and put a little bigger hole in the floor, cannot remember about length of the trans and if I had to do any with the drive shaft
I also think that these trans are not as robust as I would like but I do not beat on the car at all so it has lasted so far. I paid 275 for the T5, shifter and and attached bell housing Hope this helps |
Zip:
You are right about Muncie flex. However the aftermarket makes a cast iron midplate that reduces it significantly- at least the ones I have thrown together for guys seem to be OK. I put them together on the side for guys and use the cast iron midplate, the bigger front bearing, grooved bushing on number 1, and torq lock sliders as upgrades. I have a friend thrashing one right now in a high horse 65 Chevelle. Also if you are worried about leakage where the countershaft exits the front of the case, it can be bushed there (though I use a little permatex hi-tack and it cleans up any bit of slop in the press-fit) B, if you decide to keep the Muncie, I can rebuild it for you with the upgrades pretty reasonably- Just a fall back if you dont do the 5-6 speed upgrade. S |
Originally Posted by Scorpion1110
Zip:
You are right about Muncie flex. However the aftermarket makes a cast iron midplate that reduces it significantly- at least the ones I have thrown together for guys seem to be OK. I put them together on the side for guys and use the cast iron midplate, the bigger front bearing, grooved bushing on number 1, and torq lock sliders as upgrades. I have a friend thrashing one right now in a high horse 65 Chevelle. Also if you are worried about leakage where the countershaft exits the front of the case, it can be bushed there (though I use a little permatex hi-tack and it cleans up any bit of slop in the press-fit) B, if you decide to keep the Muncie, I can rebuild it for you with the upgrades pretty reasonably- Just a fall back if you dont do the 5-6 speed upgrade. S I think what helped bomb this last one is that I put two friend in the back seat (more weight)...got on a deserted Stretch of PRIVATE road....dumped the clutch at 6,000 rpm, banged 2nd crosssed it up ( with a Big smile I might add) was just about to get the car straight (petal still matted I might ad) and reached to grab 3rd gear and KA-BOOM,,It sounded like I was dragging the shifter levers on the asphalt under the car,,but it was actual metal tumbling in the case. ( .. DISCLAIMER -Kids dont try this at Home...I was on a shut down Airforce base, No cars,tree's or ditches ...Zip you do remember Donaldson Center AFB just up the road from Starlight Dragstrip don't you ?) |
AND THIS IS WHY ALL MY CARS GET SLUSH BOXES!! :P
The T-10 is a much simplier conversion. If your clutch isnt fine spline just put a new one in and if I remember you have to change the front driveshaft yoke to a turbo 400 style? I did it about 15 years ago on my 68 Camaro. |
| All times are GMT -8. The time now is 03:10 AM. |
