-   -   exhaust gas temp help (https://www.racingjunk.com/forums/showthread.php?t=31389)
hotrod1994 12-13-2011 05:43 PM
how do i go about increasing or decreasing it if i lean it out some and increase the timing is it gonna go up
any info is appreciated
thanks logan
oldandtired 12-14-2011 10:08 AM
Both leaner mixture and increasing timing will increase exhaust temps.
hotrod1994 12-14-2011 05:38 PM
ok thanks
maxpower671 12-15-2011 08:51 PM
not saying you are wrong but......
doesn't having the timing too late, retarded.....increase temps in the exhaust tract? instead of burning in the cylinder, the fire is started too late and is burning as the gasses are exiting..?
Scooterz 12-16-2011 09:34 AM
Maxpower has a point I think-
See previous thread Bruce commented on about Outlaws glowing header. Same principle. I too have seen this on circle track cars many times too (glowing headers)... I even had a similar problem with a XR400 dirt bike that ended up being too rich & made the header glow at idle. I think Bruce made a similar post then b/c I was making the problem worse... doing the opposite. He was right. His explanation even applies to the simplest of motors on a single cylinder motor cycle engine.
Scooterz 12-16-2011 09:54 AM
But then again maybe I am talking about two different things???
Exhaust temp VS late/ unspent gasses & ret timing??? I don't know... I am still learning. It would seem that lean & hot timing DOES also cause higher ext temp; but also a rich condition with lower timing can do it too... just by means of unspent fuel burning later in the ext tract.
maxpower671 12-16-2011 09:18 PM
Re: exhaust gas temp help
thanks logan
how about posting some info on your combination...and where you are in regards to tune...timing and your fuel delivery, etc..
hotrod1994 12-17-2011 02:19 PM
sbc
9:1
477/477 268 duration cam
torker intake
holley 750 witch is to big
some 1.94/1.5 heads stock besides springs and i had them milled to increase compression
:twisted: - logan
maxpower671 12-17-2011 06:51 PM
dear Logan,
sbc doesn't tell me much
cubic inch? bore n stroke please.......
hotrod1994 12-18-2011 07:12 AM
just a std bore 350 completely stock bottom end
not much to tell
