-   -   rocker arm ratio (https://www.racingjunk.com/forums/showthread.php?t=31483)
hotrod1994 01-02-2012 03:24 PM
rocker arm ratio
is there anything i have to do differently to run a 1.6 ratio on a sbc instead of a 1.5 rario
fast75vega 01-02-2012 03:37 PM
just install them and the push rods... then turn it over by hand to check clearances to make sure your not bottoming out the valve/springs. might have to change push rod length pending on cam size
hotrod1994 01-02-2012 03:41 PM
ok it gonna be a farily mild cam solid flat tappet 525/525 with the 1.5 ratio
hotrod1994 01-02-2012 04:08 PM
and is it worth the extra ratio it will be a 355 with 10:1 c comp 294s soild cam pro comp aluminum heads hurricane intake and a holley 750 looking to get 450 out of it
comp cams cam quest said 500 hp with the combination and that cam
burgessdg 03-09-2012 08:59 PM
Check the wipe of the rocker on the valve tip. You might need to alter the push rod length.
