compression
what's the best compession ratio for a bbc 632 that would make the best power? I'm looking to purchase a short block, my heads are dart 360 cnc.
Most of my racing is done at 4800 ft. not ajusted.Average ajust is around 7500 ft.
Depends on the gas your going to be using. We typically do 15 or 16:1
I currently use 114, I can go up if i need to. my comp now is 14.5 to 1. I wouldn,t mind going hirer if it will produce more power without problems.
Who's 114 octane, there is a huge difference between fuels brands. Adding Compression alwasy increases power.
The higher the compression, the better the parts need to be.
I think those heads will be what limits your hp unless they've had some hand work done to them.
Or do we just bump the timing a couple and suffer on the top end? Coming from Bear's dumbassed old crew chief . . . . |
Racers rule of thumba.."Heads equal HORSEPOWER!!!" |
| All times are GMT -8. The time now is 06:38 AM. |
