-   -   Help with 383 pistons (https://www.racingjunk.com/forums/showthread.php?t=31497)
srx600 01-06-2012 04:20 PM
I'm lookig to build a sbc 383 I have the block,crank and rods can I use the pistons out of my 355?
Is a 383 a special piston l or just a 350 .30 over piston?
zipper06 01-06-2012 07:14 PM
Nope the pin height is in the wrong place, the pin height needs to be 1/8" shorter to the piston deck for a 3 3/4" crank.
srx600 01-06-2012 07:21 PM
Ok thanks! That helps alot.
