RON'S FLYING TOILET "ANOTHER FIRST TIME USER"
I HAVE A 468 GM 990 HEADS, .714-.680 ROLLER CAMSHAFT, 12.9 COMPRESSION. I TRADED FOR THIS ENGINE AND IT CAME WITH THE FLYIN TIOLET. IT HAS A .39 JET IN THE NOZZLE, AND A .090 IN THE RETURN. ANY IDEA IF THIS IS CLOSE OR IS IT IN LEFT FIELD????? ANY HELP WOILL BE GREATLY APPRECIATED. ALLEN
Other than the Nozzles being on the LARGE Size it looks good!
Which is the NICE thing about a RONS set-up,BASIC!!! I would lean more in the #36 Nozzle jet. Hope that HELPS!!!! Later G 8) |
X2 the .090 return pill would be real close with a -1/2 pump. if you have a -1 pump around .115 pill.
Zip. |
SORRY, I FORGOT TO MENTION, IT DOES HAVE A 1/2 PUMP. DO I JUST CALL RON'S TO GET JETS? AND DO I NEED TO GET A FEW DIFFERENT RETURN PILL SIZES JUST FOR FINE TUNING?
I NORMALLY RUN 38-40 DEGREES OF TIMING ON A ENGINE LIKE THIS ONE, WHAT SHOULD I RUN ON ALKY WITH THIS SET UP?? |
Rons
Might want to back off the Timing a Little,Every Motor Combo is Different?
I run about 35* on my 496. Rons has the Stuff! Later G 8) Check your PM Box,...........? |
Re: RON'S FLYING TOILET "ANOTHER FIRST TIME USER"
Any idea where the barrel valve is set at ? |
Rons
I think I would rather talk to James Monroe than Rons.
(Killer Rons) James Monroe, Bloomington, Indiana. Just Google him. I was at his place last week with a friend who bought a dual toilet set up from him and he was very helpful on set up and tuning info. He has a good parts inventory too. Just my opinion of course. And I didn't menntion I have Rons parts for sale on this site, did I? |
I would get a few return pills, .080 to .100 maybe in .005 increments, i set the barrel valve between 22 and 28 percent leakdown, depending the throttle response. Nozzle size is a toss up Ex: we're running 39's on a 514" ford with a -1 pump, i run 33's with a -1/2 pump, i built a 383 and he had 31's with a -1/2 pump, then i have a freind with 427 sm/blk that runs 36's with a "0" pump, i ask him why so big, he said because it works, i couldn't argue with that since he run consistent low 5.60's at 123 mph in a 55 shoebox weighing 2650 lbs.
I usually deal with Ron's because i knew him when he started in the 1980's when i lived in phx. Not to say i have anything against James Monroe, i just don't know him and i know he's hard to get touch with during the racing season. JMO |
SORRY TO SOUND DUMB, BUT I AM A FIRST TIME USER. HOW DO I SET BARRELL VALVE LEAKDOWN?? I HAVE NEVER HEARD OF THAT NOR KNOW WHAT IT REALLY DOES. THANKS FOR ALL OF THE REPLIES SO FAR. CAN'T WAIT UNTIL RACE SEASON SO I CAN GIVE RESULTS........ THANKS.
http://www.killerrons.com/why.cfm |
| All times are GMT -8. The time now is 03:26 PM. |
