fox body max tire width
Just hoping someone could share a little knowledge with me on this.I have a 91 fox body with stock width 8.8 and I'm wanting to put a set of et streets or maybe drag radials on it.Just wondering about max wheel width and back spacing along with tire size that i can clear.I'm planning on running a 15" wheel.
O got a 90 fox and it has a mini tub done to it. I think (if I can remember right) that you can put a 10in wheel inside the well without it hitting. I dont know about the backspacing and all that tho.
Thanks man I think your right about the 10" wheel.I thought I was told that with a 10" wheel with 6.5" of back spacing you can clear a 325/50/15.Just wondering if anyone had done this for sure
If your wanting to keep the quads you will need to take and flip them 180. 275 tire would be about the widest you can fit. Hope this helps.
| All times are GMT -8. The time now is 02:04 AM. |
