Hub centric rings
Does anyone use hub centric rings with 5/8 wheel studs? I have Weld 15 x 15 Alumastar wheels and Moser axles with 5/8 studs. A respectable friend recommended I get some hub rings made up to ensure perfect centering of my rim on the axle.
Looking for thoughts. Steve |
Not sure what hub centric rings are but with my 5/8 studs I have thin threaded sleeves that screw onto the studs so they are the right size for the holes. The studs I use are the fully threaded cap screw bolts. The actual studs the have an unthreaded section are made from the right size raw stock to fit the hole right. Hope this helps or at least make since.
Curtis |
| All times are GMT -8. The time now is 11:15 AM. |
