-   -   what gear ratio (https://www.racingjunk.com/forums/showthread.php?t=31576)
ss68nova 01-21-2012 12:10 PM
what gear ratio
i have 9'' ford large pinion bbc pro street 456 gears want to change gears to much for street use what size to use for the street 540 pump gaS WITH NOS I MAY TAKE IT TO THE TRACK, TIRE SIZE 33X21.5X15 MT,
TheYellaBrick 01-21-2012 04:40 PM
Any time on the freeway ?
What is the longest distance you anticipate driving frequently on the streets ?
ss68nova 01-21-2012 05:18 PM
what gear ratio
we take the car to car shows i say 30 to 50 miles maybe more
spib 01-21-2012 07:16 PM
call up the gear companys and tell them what you want to do what rpm you want to turn they can help you figure it out
lively 01-21-2012 07:22 PM
you didn;t say which trans and car type 8)
but--with an automatic 3;73 or 3;91 would be a good combo----with a clutch 3;23 or 3;50 would work good
go to high and your engine combo will SUFFER TERRIBLY :oops:
coolracing 01-21-2012 07:47 PM
x2
ss68nova 01-22-2012 07:41 AM
what gear ratio
turbo 400 68 nova 10'' converter 3000 stall, [/i]
bbchevy 01-22-2012 08:21 AM
With That TALL Tire!
a 4.10 would be the GEAR for ME!
a 33 Tall rear Tire has a Major Factor,that ALOT of Guys DONT Understand?
Later
G 8)
TheYellaBrick 01-22-2012 11:27 AM
Tall tires = tall gearing. The land speed racing guys bolt on the tallest tire they can turn.
:D :D :D :D :D :D
TS1955 01-22-2012 04:08 PM
Re: >?
Later
G 8)
X2...I agree with bbchevy.
TS1955
