-   -   Gears for street/Strip ? (https://www.racingjunk.com/forums/showthread.php?t=31589)
Frankracing 01-25-2012 01:00 PM
Looking to find a Gear that is good for the Street/Strip ? 410 ?? Going in my 92 S10 355 sbc with a turbo 350. Thanks !!
deward 01-26-2012 05:13 AM
What Gear
You have a lot of questions to answer. How much strip, how much street? Will you be doing alot of Highway driving etc. Once you decide all this, then you can select a workable gear ratio. My experience has been that a 3:55 or 3:70 might be a good alternative rear gear.
mach401k 01-26-2012 11:46 PM
GEARS
I chose a 4:11 for my new 9". It does 3500 rpm at 65. But, I'm shooting to break 12 from my 12.8 run. I was running 3:55 8".
spib 01-29-2012 07:07 AM
there are lots of things tire size how much street how much strip, I wouldnt go any higher then a 4:11 maybee look at 4:30 gear
my wife has 4:86 gears in her s10 truck it will be very very little street use
and its got a spool
Gimmethakick 01-29-2012 07:46 PM
S-10 aint that heavy so if your 75 percent street with 28" or shorter tire I'd go with 3:55 gears.
spib 01-31-2012 07:15 PM
that would take off like a boat still tied up to the dock LOL
