-   -   A-ARM 2x3TUBECHASSIS HELP (https://www.racingjunk.com/forums/showthread.php?t=31643)
injectedrat68 02-05-2012 05:03 AM
I just picked up an old 2x3 a-arm front clip I think it an A. R .T.type. I have a back half 68 camaro Round tube chassis. OK, heres the question, i dont have the old front clip in the car any more and was trying to figure out where i should mount this clip and what height the center of spindle is. The other prob. is someone cut the rest of the fram connections off. I only have the front clip to where it would start to go under the fire wall. If you need pics i will get them or if eaiser i can call.Thanks for reading. Paul
TheYellaBrick 02-05-2012 08:51 AM
Post up some good clear pics and you'll get more help. Lot of fabricators on here.
coolracing 02-05-2012 10:43 AM
As Double D said ya need to post some pics! But shouldnt be that big of a deal.
injectedrat68 02-05-2012 11:09 AM
post subject
Thanks for replying. i will get some up
zipper06 02-05-2012 07:49 PM
Re: post subject
Don't know if you know already or not but A.R.T. is back up and running after being shut down a while, you might be able to get the mounting pads from them, maybe give them a call.
http://www.appliedracing.com/
injectedrat68 02-06-2012 02:17 AM
post subject
I have pics, cant figure out how to get them up
zipper06 02-06-2012 09:54 PM
Re: post subject
you have a PM
zipper06 02-07-2012 07:24 PM
Re: post subject
Pictures post for njectedrat68
http://img.photobucket.com/albums/v5...ulschassis.jpg
http://img.photobucket.com/albums/v5...schassis-1.jpg
TheYellaBrick 02-07-2012 07:57 PM
GOOD ! These show us what you are working with !
Now we need 4 pics of the car you want to mount this in, please. Ideally one facing the firewall, a shot of the underbody at the firewall, one facing forward from the rear seat area, and one facing forward from the rear end area.
injectedrat68 02-08-2012 02:10 AM
post dubject
Im running a stock fire wall on 68 camaro. The plan was to tie into the main cross member behind the drive seat where my ladder bars are.Because the car sits low I think if I put in the front clip i have to cut away the floor either all or just where the rails would tie into the cross member. I will get some pics to Zip to post. Thanks Zip
