-   -   sidewall punture (https://www.racingjunk.com/forums/showthread.php?t=31674)
ghustler 02-12-2012 01:19 PM
sidewall punture
Just a street tire.
It has a plug in it and its a little leaky, but the tire shops say a tire is ruined with a side wall punture.
They don't make this tire anymore and i haven't found a used one so can a patch be put in the tire then add a innertube and that be alright?
lively 02-12-2012 02:40 PM
if it is a hole -yes--if it is a slice --NO!!
ghustler 02-12-2012 03:30 PM
Yea its just a hole because its got a plug in it and it doesn't leak very much at all, but I figure on a side wall that flexes at every revolution it only a matter of time before it shoots out the plug!!!!
lively 02-12-2012 04:17 PM
YOU CAN PATCH THE INSIDE BUT MAKE SURE AND CUT THE PLUG OFF FLUSH INSIDE SO IT DOES NOT CUT THE PATCH :oops:
I WOULD NOT TRUST THIS TIRE TO RACE ON OR AT HIGH SPEEDS BUT I WOULD TRY FIXING IT :wink:
TheYellaBrick 02-12-2012 05:02 PM
Tubes don't live very long in radial tires. The built-in sidewall flex will eventually wear thin the inner tube. In an emergency situation you could temporarily run a tube but ya want to run higher air pressure to limit the sidewall flex.
RonOwensRacing 02-12-2012 07:29 PM
Go to truck stop or a truck repair shop they will tire plugs with a patch on it
you put the plug from the inside pull through then cut off the extra plug off even with the side wall i have done it a few times works great.
