-   -   which cam to use? (https://www.racingjunk.com/forums/showthread.php?t=31677)
jamez74 02-13-2012 05:53 AM
which cam to use?
I have 2 cams to choose from. wich one to prefer with 300-400 nitrous shot.
1 cam:
duration @.050 274/284
.726/.736 lift with 1.7 rockers
advertised duration 314/324
2 cam:
duration @.050 284/294
.748/.748 lift with 1.7 rockers
The engine:
Merlin3 540 cid bbc
Eagle crank and H-beam rods
dart pro1 cnc 355 heads
Super Victor Reher Morrisson intake
Race Demon 1250 cc modified dominator carb
Single stage fogger with controller
Crane HI-8 ignition
car weighs 2450 lbs with driver
4link with 32/114/15 tires
PG transmission with 1,69
4.56 gears
oldandtired 02-13-2012 06:38 AM
Need the lobe centerline & seperation on the cams.
olds48 02-13-2012 03:57 PM
Dang it,oldand tired beat me to it! He's right. The timing of the lobes are paramount on a NOS cam,more so than any other number.
jamez74 02-19-2012 12:22 PM
114.0 both on first and 112.0 both on second
jamez74 02-19-2012 11:43 PM
and compression is somewhere between 12.5 and 13
oldandtired 02-20-2012 10:21 AM
Toss up, I wish the second cam had the 114. Dave
jamez74 02-20-2012 10:33 AM
ok. but what should i order then? have any recommendations?
oldandtired 02-23-2012 05:54 AM
Personally I would go with cam #1. You can always move up as you have the compression ratio to support either cam.
maxpower671 02-23-2012 08:49 PM
like #1 as well
jamez74 02-28-2012 11:21 PM
Thanx guys!
Comp cams suggested this on. I think i will go with my old no 1 cam for this year and next year will order a new one:
Duration @ .050 282/298
Lift with 1. Rockers .806/.758
LSA 114
