What reg. do I run with carb. and alky???
I have a Ron's 0 1/2 pump, APD alky 1150 dominator. What regulator can I use. I would like to run my fuel inlet in one end of fuel log and bypass fuel through the regulator back to the cell. I know that APD sells that regulator, but what other regulators will work?????
What
Holley makes a bypass regulator now based on the original 803 one used with their fuel pumps. It is alcohol compatible and is only about $70.
I think it is 12-803BP. C&S makes one that looks the same as the Holley that has a holley jet in one end that will allow you to set idle pressure down to 3-4# and then use the main adjuster up to 15# when pump volume builds up at higher RPMs. It works well to keep the stainless steel needle and seats from dripping at idle and really pours in the fuel a WOT. |
thanks, that is the answer I was looking for.....
| All times are GMT -8. The time now is 01:35 AM. |
