-   -   LOOKING FOR SOMEONE THAT IS A NITROUS GURU!!!! (https://www.racingjunk.com/forums/showthread.php?t=31809)
fastted 03-09-2012 09:54 PM
Hows it going and thanx for reading! I think Im knowlagable on nitrous but would like some feedback. Its a new motor so I need to figure it out. I have a 706" aluminum motor olds 14 degree heads @ 28 deg timming with 2 stages of foggers. 1st stage is 26/30 jets 6psi fuel and taking out 10 degree 2nd is 28/32 6 psi fuel taking out another 10 degree. havent ran this yet, but that might be my starting point?? Of chorse I will make a 60-330 hit first on 1 stage only then read plugs and see were im at and make adjustments. Once I have that one good I'll do same to the 2nd. Then let them both go. 1st stage will come on as soon as I pull the trigger second is .8 out so I will be on both befor the 60.
Also im running vp c23 thinking about q16???
If anyone has the time to talk that knows what there talking about I would appriciate it! Hope to hear from ya!!
dw 04-15-2012 04:31 PM
you may already have found someone...but if not here are 2 of the best....
Monte Smith performance- Moulton Alabama
Steve Johnson-Induction Solutions- Florida
TheRabbit 04-16-2012 04:52 PM
You can get a quick response from either one on Yellow Bullett
