Fuel pump doesent seem to fit???
I installed my engine today, BBC 540 with ron's 0 1/2 pump. No matter how I install pump, it just does not look right. Are the fittings supposed to be pointing up or down? I am going to run a carb to start with being so new to alky. my pump is gold, black bracket pump bolts to is a 8501-A and another bracket bolted to it that is a 8506. I need help, or maybe a pic of someone's on there motor??? Thanks for any help.
fuel pump
killerrons.com
AKA James Monroe |
I looked on their site and really cant make heads or tails of their diagram. I hate to sound so dumb, but my pump does not look like the one on the diagram??? Pump say's Ron's right on it.
Fuel pump
You have a private message. Look near the top of the page.
I drilled a new hole in my front plate to make everything work out and look right. Thanks for the help. Allen
The newer pumps have a slip collar where you can rotate them to any position, i personally don't run Rons pumps, i run DSR pumps, but everyone now makes the slip collar pump.
Zip. |
Thanks Zip, I have a older pump, I think I may have to upgrade later in the season.
| All times are GMT -8. The time now is 01:29 PM. |
