-   -   1994 ford f150 tranny problems (https://www.racingjunk.com/forums/showthread.php?t=31821)
jakethesnake55 03-12-2012 09:19 AM
i got a 1994 ford f150 with the 302 automatic transmission 4x4. the bell-housing is all one unit with the transmission. well my bell housing has a crack in it all the way around, i pulled it out and called the transmission shop. i was told the transmission is the E4OD. now i took it to town to buy a new one but he told me my transmission isn't the E4OD. he said it was one similar but had a "W" in the model. does anyone know which one that might be?
TS1955 03-12-2012 09:50 AM
If it has a 20 bolt pan it's an E40D. If it has a 14 bolt pan then it's an AODE/AOD assuming it's an over-drive trans. If not then it's a C-6.
TS1955
