-   -   front skinnys (https://www.racingjunk.com/forums/showthread.php?t=31990)
mmphillips 04-16-2012 02:42 PM
front skinnys
I have a 70 nova that im wanting to put 15x3.5 weld draglites on the front.I dont know what size tires to go with 155/80/15 or 165/80/15 . im running 235/60/15 drag radials in the back.thanks for helping!
blazaboy86 08-05-2012 07:32 PM
I just ordered 15x4 for mine, and 165/80
outlaw256 09-19-2012 04:18 AM
165 / something lol i still think of the opld #s like 550 x 15. i just tell the tire people i want 70 model bug tires.lol run them on old 15 x 3 1/2 cragers.
BEAST477 10-19-2012 04:03 PM
Not sure how fast you guys are running, just make sure the tire you buy is rated for the speed you intend to run. Wrecking your car or someone elses isn't worth saving a few bucks.
dartsteve 01-25-2013 02:47 PM
Many 3.5 and 4 " rims are not highway rated
oldandtired 01-28-2013 02:35 PM
OK, need my buddy Yellow to chime in. He has the tire temp to deal with.
The speed rating on a tire is based on so many seconds/minutes at the speed rating of the tire. On a 1/8 car I have run a "T" rating (118mph) tire knowing it would only be for 1-1/2 seconds per run. Do you condisier this an overheating problem?
TheYellaBrick 01-28-2013 03:08 PM
1/4 mile at a time at higher than rated speeds is pretty safe. UNTIL you are getting into the 120 mph range. STILL run load rated tires FOR YOUR VEHICLE WEIGHT!!!! It is the 'extended' time at speed as well as the ambient/ road surface temps is what are tire killers. A tiny 'overloaded' tire on the street is NOT recommended even though most of us(me included multiple times) have done so. Even more dangerous is running a spool on the street with tinys up front as you can do serious tire sidewall damage at low speed 90 degree turns and or pop 'em off the rim altogether.
