-   -   compression ratio (https://www.racingjunk.com/forums/showthread.php?t=32004)
hotrod1994 04-19-2012 02:30 PM
compression ratio
can i run 11:1 in a 406 sbc on pump gas 91 octane no ethanol added?
thanks
-logan
oldandtired 04-20-2012 06:14 AM
Do you have alumnum heads?
Carb or FI?
hink 04-20-2012 09:25 AM
Re: compression ratio
thanks
-logan
You should find out what your dynamic compresssion and go from there!
hotrod1994 04-21-2012 07:58 AM
carb and it'll probably have procomp aluminum heads unless i can afford more when the time comes
bubbaf100 04-30-2012 11:07 PM
Pro Comp are junk
Save your money and buy USA Made Heads!!!!
Pro Comps are junk.
Have bad installed valve guides,some have stripped stud threads, some are 20
to 30'' of being straight,some come cracked, and many other problems with
cheap labor.
I sold Pro Comps for 3 months out of 74 sets I've sold after 2-8 months
39 sets had minor to major issues. 23 sets were unrepairable or too expensive
too even attempt to fix.
JMO Save your money buy AFR,Brodix,RHS,Dart heads. 8)
Only a rich man can afford to buy junk because he has plenty more to dig himself out if all else fails.
wrightway 05-01-2012 04:53 AM
thanks
-logan
x2
markdunlap 05-01-2012 05:37 PM
Compression
Have you looked at water/alcohol injection? Reduces detonation potential.
Was a fad a few years ago and its back again. I see it in JEGS.
You can use windshield washer fluid.
It is $300 approx for the kit.
