switching to alcohol
Do you still run the foam in the fuel cell and can I run the return to the other bung on the bottom of the cell?
Re: switching to alcohol
Later G 8) |
no foam on cell , return has to be on top of fuel cell, alcohol doesnt like alot of timing , probably 28-33 degrees on a bbc depending on motor, start with a fat tune , and go down form there , its safer you may milk oil a little but its better than blowing it ...
I am running my first alky set-up this year, my only advice is go with a well known carb. builder "APD, Rupert" being the best in my opinion. Mine is a APD, I took it out of the box, bolted it on and never even adjusted the idle. After I fixed my car issues, it is DEADLY AND I RUN 4 RACES BEFORE OIL CHANGE, just cause I felt guilty. It still looked like new.
APD 419-855-3073 JOHN KYLE |
NO & NO Later J.Smith 4621 racing
thanks for the help. I will be running a Ron's Toilet on a bb chev
| All times are GMT -8. The time now is 07:56 AM. |
