-   -   question about clutch ??? (https://www.racingjunk.com/forums/showthread.php?t=32159)
sirswapsalot 05-26-2012 04:31 PM
i have a 55 chevy, big block, 9 inch rear with 3.90 gears,
it has a muncie 4 speed with a Hays clutch,
it comes out of the whole hard through all 4 gears
QUESTION is putting long around 2500 rpm in 4 th gear if i just floor it it reves up to 4500 real quick before it starts pulling ?
Do u think my clutch is slipping ?
thanks for your help
gearhead1011 05-26-2012 06:27 PM
Depending on what set up you have there is probably nothing wrong with it. The pressure plate probably uses a light base pressure and has counter-weighted levers that increase pressure as the RPM increases. There are a lot of different Hayes clutches and would need more info on what you have to know. A good performance clutch slips some but driving it around at low speeds and slipping it like that will ruin it.
oldandtired 05-29-2012 11:17 AM
It sounds like a slipping clutch to me. You will know if you smell it, nothing else like it.
