-   -   8.5 posi noise (https://www.racingjunk.com/forums/showthread.php?t=32161)
hotrod1994 05-27-2012 06:58 PM
8.5 posi noise
gm 8.5 posi make clunking tapping chattering noise when turning?
what could it be?????
it a stock posi carrier 4.88 gears
gearhead1011 05-27-2012 08:08 PM
It might just be the clutches chattering and a little friction modifier should fix that. It's possible there is damage to the spiders so it wouldn't be a bad idea to pull the cover and have a look. If you don't find anything broken then some fresh synthetic lube and a bottle of additive should make a difference.
hotrod1994 05-27-2012 09:44 PM
ok thanks
TheYellaBrick 09-26-2012 06:23 AM
Go AWAY AZZ HOLE !
