-   -   ford 9 inch (https://www.racingjunk.com/forums/showthread.php?t=32225)
hotrod1994 06-11-2012 05:16 PM
ford 9 inch
anyone know how much the pinion is offset on a 9 inch compared to an 8.5 10 bolt and do i have to center the pinion or can it be offset by ? amount and work fine ?
thanks logan
roadkill2 06-12-2012 05:43 AM
In Theory, a drive line is supposed to be as straight as is possible, both vertically and laterally. Generally vertical is set so that the driveshaft will be it's straightest when loaded (Torque Applied). Lateral is kind of a "No Brainer", and should align with the centerline of the crankshaft, or at least as close to it as possible.
U-Joints aren't intended to compensate for mis-alignment of driveline components, but to allow for the movement of the suspension. Granted, we get by with a lot of mis-alignment, but according to all of the engineering I've been schooled on, the straighter, the better . .
Plus, Just to reitterate, your whole rear suspension works off the radius created by the centerline through the front U-Joint. If your rear suspension isn't designed to work through that radius it will be in a bind and will not function properly.
Based upon prior experience, I'll expect a lot of differing opinions on this particular subject.
hotrod1994 06-12-2012 09:37 AM
ok you wouldnt know how much the pinion is off set would ya?
TheYellaBrick 06-12-2012 04:02 PM
http://www.currieenterprises.com/ces...mrearends.aspx
http://www.enjenjo.com/9inch.html#pinion
http://www.kevinstang.com/Ninecase.htm
gearhead1011 06-12-2012 06:27 PM
If you want to know what the offset is from the center of the case I think it's right at 2 inches.
TheYellaBrick 06-12-2012 08:03 PM
Unless you offset the drive line/engine/trans you're gonna have a short axle on the drivers side and 2" longer one on the passenger side.
