-   -   5.3 ls (https://www.racingjunk.com/forums/showthread.php?t=32233)
hotrod1994 06-15-2012 02:46 PM
5.3 ls
looking to maybe do an ls swap with a carb and such anyone know what kind of a cam i can run in a stock 5.3 without changing valve springs ?
thanks logan im thinking with a cam headers and a few other things i could have a 400+hp ls
thanks logan
roadkill2 06-16-2012 07:44 AM
Don't wanna sound like a wiseass here, but when you ask your valve train to do more than it was designed to do, generally, you start finding the chain of "Weak Links" . . Performance demands longer Valve opening times (duration) and greater Openings (Lift). The duration won't hurt much, but lift will kill you . .
Springs, keepers and rocker studs are gonna know you're trying to "Cheat" on 'em . .
If you want to sound bad at a stoplight, pull a plug wire and take off the muffler. If you want it to get on the tire, get out the wallet and don't get too crazy with the lift . .
hotrod1994 06-16-2012 08:19 AM
ok i found a spring and retainer kit from patriot for a good price so if i go this route ill pick it up
bluedawg357 06-16-2012 11:05 AM
Super Chevy has a current series article called modern mouse. Lot of information no matter how biased it is.
bluedawg357 06-16-2012 11:06 AM
chevynovaman 06-18-2012 04:29 AM
5.3
LOGAN,
I CAN SETUP THE 5.3 FOR YOU WITH ALL THE INFORMATION YOU NEED, I HAVE ONE IN MY 57 CHEVY AND IT GOES GOOD WITH GREAT MILEAGE.. ALSO JUST DID A 6.0 IN A 68 CAMARO.. COME AND SEE ME.. R.C.
hotrod1994 06-18-2012 09:26 AM
might take you up on the offer ryan thanks
chevynovaman 06-18-2012 01:14 PM
LS1
LOGAN,
STOP BY THE SHOP ANY NITE OF THE WEEK, GETTING THE ELCAMINO READY AND TUNING " "SPRAY"" FOR THE 30TH AT MUDDY 13 MUD DRAGS R.C.
hotrod1994 06-18-2012 08:51 PM
ok ill let ya know i think ive got your number still so ill shoot ya a text
i don't have an ls ready for a swap yet but the more mpg with more power is sounding really good right about now
chevynovaman 06-19-2012 07:30 PM
LS
LOGAN,
IF YOU ARE ABLE TO GET A 6.0, WITH JUST A COMPUTER TUNE AND HEADERS YOUR LOOKING AT 440 HP, INJECTED WITH DOUBLE THE MILEAGE YOUR GETTING NOW.. I GOT MY 6.0 FOR 900 TWO MONTHS AGO..... 421-4080 ..
