29.5 10.5w mt can i use 14 inch wide rim
can i use them on non beadlock wheel
14 inch rim
Strickly a guess, but I would not do it. It may even be hard getting them to bead up on that big of a rim after mounting ?
I have put 10.5 tires on 8 inch rally wheels and ten inch rims. No scientific info on it, just my opinion Good Luck Jeff |
First; why not use the proper sized wheel ?
Second; is too wide a wheel will 'cup' the tread so that only the outside edges actually do the work. The opposite is true for too narrow a wheel, the CENTER of the tread does all the work. You'll not be getting the FULL contact patch that would be the most effective AND uneven / premature wear. Also, too wide a wheel (without bead locks) you have a greater chance of sidewall collapse under launch and wall contact after collapse. Tires are the greatest cause of wrecks in racing. They are the 'weak link', and you want that link the strongest possible. SAFETY FIRST |
We (I) have done it years with 33x10.5w tires in outlaw racing. Purpose of this to flatten out the foot print of the tire to get more tire to the ground (foot print wise). I also run double beadlocks. No sealing issues. Do not know about 29.5s. So rather say somthing that could get you hurt or killed. I say call some 10.5 pros such as steve kirk,tim lynch etc.. Guys like this are easy to get in touch with a can tell you for sure with experience behind it. jmo
Brian |
I don't think i would do it without beadlock's :!: :!: jmo
Mark |
car was made for 15inch wide tires rims have 3 inch back space. by tires r junk the 10.5 w were free and free is good lol
your question was concerning will a 29.5(w) tire work on a 14 inch wheel. Now I have read your last post, about how your car was built and back space and free...etc..it obvious to me you have no clue what you are doing.. I agree 100% with Fast75Vega, Go buy the right size tires for the wheel..if ya gotta run free stuff then get out of Racing....its not just your life but other drivers beside you also. did you happen to read the latest sticky from one of Our senior members...just in case here is the thread.....I am done here... read slow and multiple times if needed : http://forums.racingjunk.com/viewtopic.php?t=18505 |
thanks for the replys i wasnt going to run them anyway it was a guestion!!!
and bjuice u need two slow down there hot rod . have a great day everone |
:shock: :shock: Say What !?
| All times are GMT -8. The time now is 02:48 PM. |
