-   -   valve cover gaskets where push out (https://www.racingjunk.com/forums/showthread.php?t=32244)
vega 06-18-2012 02:25 PM
first test run with are new car and motor...and it push out gaskets we have a 565ci motor with a vacum pump its showing about 9# of vacum motor was dynoed all good then way is pushing valve cover gaskets the gaskets were the cork ones thanks for the help
BEAST477 06-18-2012 04:40 PM
Get rid of the cork gaskets and get the rubber ones with the metal insert and dowels around the bolt holes, can't over tighten them.
Is this a new vacuum pump? Have you cleaned it and lubed it lately?
Is it pushing the gaskets out or sucking them in?
hammertime 06-18-2012 05:37 PM
x2 on ditching the cork gaskets and getting a set of good rubber ones.
fast75vega 06-18-2012 05:57 PM
yes sir :wink:
TheYellaBrick 06-18-2012 08:09 PM
:shock: :shock: I didn't know anyone USED cork one's anymore !
:shock: :shock:
