Rewiring Brake Light
I'm in the process of rewiring a race car (85 camaro) that had the worst case of wire bloat I've seen. I need to wire in a brake light. It wasn't wired for one before. Is it as simple as attaching a switch that gets activated by depressing the brake pedal and running a wire to the tail lights?
Re: Rewiring Brake Light
Don't forget to fuse it BEFORE the switch..........
There is a neat little pressure activated switch that plumbs into your brake line available for $10.00.
So what is the switch called and where can I get it? Thanks.
Painless Wiring 80174 - Painless Performance Low Pressure Brake Light Switches
Here's a picture of a pressure switch for a 62 Ford Galaxy.
http://www.rockauto.com/catalog/moreinfo.php?pk=1185671 |
Am I right is assuming a T fitting is put in the brake line coming off the master cylinder? Do I feed it 12v and the pressure switch lets the 12v go out the other wire?
I use the high pressure switch off a T in the brake line . You can wire it both ways:
Power thru the switch to the tail lights to ground. or Power thru the tail light to the switch to ground. Of course as DD said, "fuse it..." Speedway # 910-31305 identical to the Painless part. |
| All times are GMT -8. The time now is 06:51 AM. |
