-   -   400 SBC head gasket (https://www.racingjunk.com/forums/showthread.php?t=32313)
testcase 07-10-2012 06:41 PM
400 SBC head gasket
I am at the point where i need to decide on a head gasket for my bracket motor.
It;s a 400 + 0.30, factory 509 block with brodix alum. heads. An honest 12.5 compression ratio computed with a .41 head gasket.
N/A, no power adders no steam holes in the heads
I am thinking a Fel pro 1003 should be adequate for a 600 hp level, but I would like to hear some opinions
zipper06 07-10-2012 07:33 PM
I run the same motor with Brodix track 1's except more compression. i would not run a 400 blok without using head studs vs bolts. In fact i have 2 400 blks and both are studded. I also use felpro gaskets.
JEFF69Z28 07-12-2012 08:28 AM
Be careful with those sbc factory 400 blocks!
curtisreed 07-12-2012 12:50 PM
We run that same gasket on a 406 that has an honest 15-1 static CR. Stock block, alum head, with studs. This motor made 702hp. Not sure how happy the dyno was but it runs low 9.40s in a 2850lb nova, shifting at 6400, leaving at 3800. It is injected on alcohol. Watch your tuneup at that hp level using a stock block. Some people get away with running them some don't. We had ours sonic tested to make sure there were no thin spots.
This was a 2bolt block with splayed caps installed.
Curtis
