-   -   rims size question (https://www.racingjunk.com/forums/showthread.php?t=32322)
bixblk 07-11-2012 07:33 PM
rims size question
Hello folks
Does anyone know what backspacing I should use on my 70 chevelle rear rims. I have ran 8 in welds (4.5 in B/S) with 10.5 tires , but I am thinking about going to a 10 inch rim with the 10.5 tire.
Stock width rear end ,not tubbed,. I know I can figure it out once I get everthing in front of me car/ rims tires, but I thought maybe someone may have some previous experience.
Jeff
TheYellaBrick 07-11-2012 07:38 PM
How much room you have inside and out with the 8" rims ?
Are the 10's a zero offset ? ( 0 Offset being 5" back space)
Are the tires tucked down into the wheel well(car lower than stock) or is it jacked up thus exposing the whole tire ?
bixblk 07-11-2012 08:14 PM
rims
I have not bought the 10 inch rims yet, so I can get any B/S or offset that they sell. I will set the car down and put the 8 inch rims/slick combo on and check everthing out and see which way I have direction and how much room I have . The tires/rim combo currently fit completely in the wheel well and I want to keep it that way.
Thanks DD
outlaw256 07-12-2012 03:17 AM
unless you are building a "donk" they are wheels not rims. lol
dragonmaster093 07-12-2012 04:43 AM
i beleive that a 5 inch to 5 1/2 bs will work they are basically the same wheel wells as 73-77 and i know thats what the guys on another forum run
TheYellaBrick 07-12-2012 06:00 AM
Since I'm a Mopar guy, I've not much 'exposure' to Chebbys, is that a coil spring rear suspension ? If so you usually have almost no probs with contacting suspension parts(like leaf sprung Mopars) but the inner wheel well will restrict your choice unless you tub it.
Harbone 07-12-2012 06:29 AM
Do some research on this forum
http://www.chevelles.com/forums/
I bet you can find an answer there. Its gonna be tight and you might have to roll the fenderwell lips to keep them from rubbing the outside of the tire.
bixblk 07-12-2012 04:31 PM
rims.... oh sorry wheels
Thanks guys I do appreciate it.
Jeff M
Scooterz 07-12-2012 05:18 PM
Harb is correct. I have 10" Welds on my 68 Chevelle right now & they do not fully clear the fender well lip when the car is lowered down... they will rub on the first 2" of the tires. If I bring it up (top of tire just under the lip) they clear w/ my Weld Drag lites.
dragonmaster093 07-12-2012 10:55 PM
rigs whats your bs on those rims
