-   -   flat tops with 306 duration cam???? (https://www.racingjunk.com/forums/showthread.php?t=32383)
ejm 07-23-2012 05:29 PM
i have a 454 .030 over stock crank and rods fattops and 049 bbc heads wondering if the 11-220-4 comp cam will work for that setup? heads are setup for cam but didn't know about compression ratio??
bluedawg357 07-24-2012 08:03 AM
Wallace racing has a dynamic compression ratio calculator, with aluminum heads and pump gas with a good quench you want your dcr to be under 8.5.
SPEEDNEEDS1 07-24-2012 01:30 PM
I once had a 454 flat top std bore truck engine with a 305H .575-.575 lift cam and it worked great. Engine went 6.90 @ 3600lbs, but I did have a set of 291 cloced chamber heads. Hope this helps.
