motor mounts
I have a 68 javelin, I,m putting in a 350 4 bolt main,cant figure out how or what to use for motor mounts? any ideas????
Depending on what you want to use the car for,there are several different options. Engine plates are by far the easiest to install,but it makes accessory mounting a PITA. Best bet is to either fab up some factory style mounts,or find a shop that can do it for you. ICBW,but i seriously doubt there are any bolt-in kits for your application. Good luck!
| All times are GMT -8. The time now is 06:07 PM. |
