bbc used piston question
thinking about buying a set of used pistons, they are keith black 787 my motor is a stock crank and rods open chamber heads my question is that on kb website it shows these with a 4.25 stroke and 6.385 rod can i still use with a 4 in stroke and 6.135 rod?
No. Your piston will be .500 down in the cyl at TDC if I did the #'s right.
k but if a guy picks them up for 125 is it worth finding a set of 6.535 rods?
You would still be down in the cyl and I forgot in my first post crank throws to piston skirt clearance might still be an issue.
ok thanks for saving me some cash
No problem. If you have a reputible engine builder close by that you trust you can check with him also.
really good question,
and even better answers! Solid!!!!!!!! unless you have a good use, or want to put them on the shelf for later.....pass........ |
| All times are GMT -8. The time now is 06:28 AM. |
