-   -   SBC 4/7 swap headers (https://www.racingjunk.com/forums/showthread.php?t=32464)
bubbaf100 08-10-2012 11:38 PM
What header designand size would be best for a SBC 421?
10.5 Compression AFR 235 heads,Demon 1050 carb, Edelbrock Fully Ported Super Victor, 675/645 278/284@50 106ICL 110 lobe sep. 4/7 firing order swap.
Need headers for drag use.
TheYellaBrick 08-11-2012 05:54 AM
What's it going in ?
zipper06 08-11-2012 09:33 AM
2" to 2 1/8" step headers with 4" collector, nothing smaller than 2" for sure.
bubbaf100 08-11-2012 11:08 AM
Going into a 78 C10 Blazer.
No fenderwells. Build headers first then put fenderwells
back or actually cut them to fit.
cncmotorsports 08-14-2012 09:52 AM
Re: SBC 4/7 swap headers
Are your heads spread port exhaust?
bubbaf100 08-16-2012 05:49 AM
Yes it is a speadport exhaust.
cncmotorsports 08-16-2012 06:10 AM
1 7/8 to 2 inch, or just 1 7/8
You need more compression.
bubbaf100 08-16-2012 04:52 PM
I'm limited to 91 octane and a dish piston by rules.
I wish I could have more compression.
I have to run a 30'mile street test.
I have that taken care by a dual fan and dual radiator setup.
TheYellaBrick 08-16-2012 08:02 PM
what kind of event are you runnin', Anyway ? :shock: :shock:
bubbaf100 08-16-2012 10:40 PM
Ventura County Street Outlaw.
Up to 440ci displacement.
Limited to only smallblocks with 23 degree heads(On Chevy's)
Single Carb only unlimited induction.
Chevy's 23 degree heads Unlimited Modifications.
Limited to dish piston and 91 octane pump gas.
Unlimited transmission and unlimited rear end.
Unlimited Cooling.
Unlimited tire.
No power adders.
In the future I'll change classes and run 14:1 on Alky.
Dual 950 RS Demons with Hogan Sheetmetal intake.
Top it off with a Dual shot Fogger. 150 at the gate and another
200 shot. I'm crazy I'll still drive it then on the street too.
