-   -   shortening a factory driveshaft (https://www.racingjunk.com/forums/showthread.php?t=32474)
sds10racer 08-12-2012 02:49 PM
have a 64.5 x4 inch alum shaft out of my dsl pickup and am wondering if it will hold up to getting it shortend up 7inches to the same length i have in my s10 now. not a lot of pwer now, but want room to get more hp later.
fast75vega 08-12-2012 03:09 PM
should hold up fine... get the HD u-joints put in it too :wink:
TS1955 08-12-2012 04:23 PM
X2
TS1955
sds10racer 08-12-2012 05:35 PM
thanks for the replies. now just have to check the driveshaft shop that made my last one to se if they do aluminum ones or not. by good joints, should i get the spicer solids(that i usually use) or can i use the precision brand. i see they are owned by moog.
fast75vega 08-12-2012 06:33 PM
as long as they dont have the grease fittings.... that usually the weak point and where they fail :(
sds10racer 08-12-2012 07:21 PM
i agree. this is goin to be a winter time change as I've not been doing any racing as my puller engine went down.
