-   -   bearing clearances bbc (https://www.racingjunk.com/forums/showthread.php?t=32626)
ejm 09-16-2012 06:19 AM
getting ready to put together 454 .040 over forged 4" crank factory rods (stess tested and ballanced) kb hyp 257 pistons 781's with 2.19 int valve bowl work and a .629 lift mech flat tappet wanting to know bearing clearance on mains and rods and endplay and if you could throw out some hp and tq numbers?
zipper06 09-16-2012 07:50 AM
If the crank measures standard, i almost alway buy .001 over bearing on both rods and mains, giving me .002/.0025 clearance, .022 side clearance.
I hope you put new good ARP bolts in the rods.
ejm 09-16-2012 08:38 AM
yes they have arp rod bolts
ejm 09-19-2012 03:29 PM
what is the best way to set thrust bearings? have all toqed and loosen rear cap pry back and then forward with crank then torque?
zipper06 09-19-2012 06:12 PM
Right on, pry forward last then torque.
