-   -   Help with build. (https://www.racingjunk.com/forums/showthread.php?t=32717)
black76nova 10-13-2012 10:52 AM
Help with build.
Need some help with engine and transmission install in 76 nova. putting in 383 and 700r4 any and all help is welcome.
ajk 10-13-2012 12:18 PM
First thing you will need is a 76 Nova, then.....lol
What do you need info on or help with? Alot of knowledge on this site. I am sure they will chime in when you are more specific.
Al
Harbone 10-13-2012 05:25 PM
motor should drop right in if it was an original V8 car, I do believe you need a different trans crossmember and will have to shorten the drive shaft if you use the 700R4.
