2012 BLP Carb Shootout
Here is the links for this years Carb Challenge at BLP. There will be a mic outside the dyno room for interviews, so you will hear a little interaction this year.
Small Block Saturday and Sunday http://new.livestream.com/speedwayillustrated12 Big Block Monday and Tuesday. http://speedtalk.com/carb-shootout.html There are two fuels used for each engine, VP113 for the small block, Rockett 118 for the big block, then methanol for both. The small block will be the same as last year with a slight change in RPM range, 4000-8000. 430 SBC Mullins Racing Engines built with 14 to 1 and 23˚ heads. The Big Block is a different animal this year, Steve Schmidt will be supplying a 15 to 1 582 with the new SR-20 Brodix heads and intake, estimated to make 1175 HP. Pull range will be 4500 to 8000. |
| All times are GMT -8. The time now is 07:38 PM. |
