-   -   trans leak (https://www.racingjunk.com/forums/showthread.php?t=32847)
john910 11-25-2012 06:25 AM
trans leak
i have a powerglide that has a small leak coming from the shift rod that goes in the side of the case. possible seal? can that be fixed with out pulling the trans apart?
john910 11-27-2012 03:49 AM
trans leak
looking to see if the shift rod can be removed by just droping the pan or does the valve body have a come out also?
itsabird 11-27-2012 04:21 AM
You can remove, the shift rod by droping the pan, you will need enough room to slide it out.
