Carb Problem
I have a Speed Demon, #1402010, which is suppose to be a 750 cfm. When I put it on my street 454 and it seemed to drown it with fuel. I then switched to a Holley 650 cfm and it runs better. But I thought I'd get more power with the 750. Any suggestions? Here is my engine run down:
454 block forged pistons - 10.75:1 compression new chromoly rings cam - .544 lift roller rockers rebuilt open chambered heads Weiand aluminum intake Mallory distributor Stock mechanical fuel pump |
There are a few things to look for. Since is seems to run ok with the 650 you fuel preesure should be alright. Check your float level. Then make sure your jetting is in the ball park for that carb. Do some research to find out the factory jetting should be. That will be a good starting point. Then check your power valve(s). They could be ruptured or wrong for your application.
TS1955 |
id be lookin at that 750 carb.like float level for starters.that engine should be able to handle 750.
A larger carb doesn't always mean more power. Lots of things to consider. The biggest thing is calibration. It's got to be right for the motor it's on or it won't make a difference at all, and can even lose power. I'd take that carb completely apart and blow out all the passages, make sure there's no debris in it at all. Put it back together and set the floats with the level at the bottom of the sight glasses to start, and see how it does from there. What jetting, air bleeds, etc are in the carb? Did you get it used or new?
carb
That motor should like a 750 cfm carb.
All the above info /tips I agree with. I have put 850 CFM DP holleys on 454's with similar parts, and it was fine. You probably have a carb issue with the 750 Good Luck |
thanks guys.
750 carb
that holley 750 out of factory should have 75 front and 75 rear jets with a 6.5 power valve in both front and rear. no power valve in rear, then step rear jets up to around 82(and try 84s). you may have to step up the timing at idle to get the carb to idle properly(and remove some timing from the full advance position) art
| All times are GMT -8. The time now is 03:42 AM. |
