moly vs mild steel chassie
looking for input on weather to build new round chassie out of?
cert to 7.50 strut/ 4 link i understand total weight savings will be 100 lbs for moly. is the moly worth the extra cost and tig welding ( i currently only have mig) this car will only run a few times a year |
CM, tigged and overbuilt in case you ever need to sell it, it would be much more marketable if done up real right. And also safer if you ever 'needed' it.....
I agree with Brick and the xtra 100lbs will be worth it to run in the 7s.
Carbon vs. Moly Tube
So . . . , you gonna have a lot of time and money in this effort . . . . .
Sort of like restoring a '57 Chevy or a '53 Chevy. Same amount of time and parts, but the end result is very different ($$$$$)!! Take care, K |
| All times are GMT -8. The time now is 09:35 AM. |
