-   -   bbc heads (https://www.racingjunk.com/forums/showthread.php?t=32977)
showbusiness 12-29-2012 03:56 AM
bbc heads
Wondering what heads to consider on a 468 for race use only on c16 with a .700 lift solid roller set up, wanting 750 plus hp, RHS 320,AFR,BRODIX,VICTOR etc. :?
wazup 12-29-2012 08:02 AM
I run brodix but i geuss is how much do you want to spend. I think with any of the heads mention you should be able to make 750hp with the wright work done to them. Good luck on you build.
Robert
zipper06 12-29-2012 08:41 PM
Don't know what's best choice but i built a 468" bone stock bottom end except Probe 10.25 pistons, using a good set of BB2 Extra heads fully ported, and a 6.58/6.63 roller, 454R itake and 1050 dom. It's runing today after 2 1/2 yrs. and about 100 passes. It in a 66 Biscyne that runs 10.30@129MPH on motor and the car weighs 3700LBS minus driver. It runs [email protected] on 200 shot of nitrous, all with 1 7/8" headers. He fills up the tow vehicle at Shell station and the 10 gal rear tank in the race car with 93 octane and goes to the track. But as i said all heads are similar, but i only know how the BB2E's perform.
Car as mentioned, it's also for sale for $18,000,00
http://img.photobucket.com/albums/v5...Biscyne001.jpg
