-   -   sbc carb (https://www.racingjunk.com/forums/showthread.php?t=33070)
hotrod1994 01-19-2013 06:08 PM
sbc carb
750 dominator on sbc
10.5:1
aluminum heads
forged internals
comp xs290s cam 520/540 lift
im thinking a 750 dominator is a little big but how do you guys think it would work
cbtlr 01-19-2013 09:32 PM
I'm running a mild sbc 350 with Eddies performer 70cc heads flat tops rv cam..Purchased a AED 750 dbl pumper 73 jets up front with 4.5 PV..Rear jets 80's no PV..My sb loved that AED 750...You have a bit more motor than me..My 292H cam is in route..
coloradoracerguy 01-20-2013 05:28 AM
A 750 dominator is the same as a 750 double pumper in airflow, but a completely different carb since it's a dominator based carb. They use skirted boosters to kill airflow through the carb. It's calibration is in need of rework, as they weren't very good. So to answer your question, you'd be better off with a standard 4150 carb over the dominator, but it's still going to have to be calibrated for your combo.
cbtlr 01-21-2013 07:20 AM
^^^^^^ Great info I did not go into details..My point was many told me my sb would not like the 750 cfm..My time slips told different...That Dom carb may help or hurt only one way to find out...
