-   -   e.t estimate (https://www.racingjunk.com/forums/showthread.php?t=33079)
hotrod1994 01-21-2013 08:31 PM
e.t estimate
355 4 bolt mains im estimating around 475 500 at the crank.... yes? no? ???
11:1
scat forged crank
pro comp 5140 chromoly i beam rods
pro comp 215cc aluminum heads 2.02 1.6 valves
comp 306s 555/555 lift 306 duration
hurricane style intake
holley 750
th350 stage 2 shift kit and 4000 stall
4.88 gears
29x12.5 m/t sportsman pros
3500-3700 lbs aprox.
max rpm 7000-7200 some where in there
looking for E.T estimate
txetracer 01-22-2013 09:37 AM
I think the crankshaft HP will be more in the 440-450 range. The combination sounds good but your real HP limiting factor is the cubic inches. The other issue I see will be traction. That considered, I would say 7.90 - 8.20, in the 8th. Theoretically, there is more e.t. in that HP. I'm just thinking that without slicks you will not see it...
Do yourself a favor and keep the max RPM's and shift point more in the 6800 or so range. I don't think there will be a difference in 6800 and 7200, but your engine will last longer at 6800.
My opinion is worth just what you paid for it. :)
Good Luck & Great Racing ! ! !
Jeff
hotrod1994 01-22-2013 10:01 PM
just gonna be ran on the street mostly anyway not gonna see 7000 alot like a all out drag car would it's only gonna see that when i need to shut someone up :) as far as c.i i was gonna go 383 but my machinist said it's a pain in the a$$ to notch the block and it really wouldn't be worth the hassle if it was just gonna be a street car for the most part, the sportsman pros are suposed to have a wrinkle wall design and be a drag compund tire but we will see how it hooks up i guess
thanks
-logan
roadkill2 01-24-2013 06:06 AM
The best estimate for any Drag Car's performance comes in the first pass that you make clear through the quarter . .
Anything before it is a wild assed guess and anything after it is hopeful thinking . .
Heheheheheheheheheh . . . . .
bluedawg357 01-31-2013 10:54 PM
thanks
-logan
Its not that hard to clearence the block and in my opinion well worth the extra money for the power gain and flatter torque curve.
bluedawg357 01-31-2013 10:55 PM
thanks
-logan
hotrod1994 02-04-2013 08:07 PM
yeah im just gonna go 406 i forgot all about the 400 block i had out back
Scooterz 02-11-2013 01:53 PM
Just guess... in a body @ 3600-3700lbs, @450HP w/488's & 4000 stall you should be able to run 15 seconds or less. :lol: :lol: :lol: :lol: :lol:
Nah seriously, you will be a serious threat on the street from light to light. Not one kid with a FART CAN & A LAP-TOP will touch you... go get em.
hotrod1994 02-12-2013 08:08 PM
thats what im lookin to do :) EAT RICE!!!
