292H camshaft ?
Will this cam cause issues with power brakes without a canister?
Thanks in advance... |
brakes will be soft and wont stop very good but you might get by without a canister
It'll be softer, but it will not be so bad. It will stop good. Not so bad that like its going to be a runaway freight train. I have a solid 314/318 540/585 on a 108icl 112 lobe sep. I drive this SBC 400 on a daily basis in a C10 Blazer with a 6 speed. 3.73 rear eaton limited slip. The pedal is soft but not that bad I'm not running a vacuum canister.
CBTLR,
I ran this cam back in 1979 in my 67 RS -it was known as CCH-292. Great cam -No brake issues and it pulled hard to 7000 RPMs with Torker Intake, 300 hp heads, 327 flat top Won a lot of races back then |
Originally Posted by alexu
CBTLR,
292 cams are a old grind. but still really good for makin ol time power on the street. ran them back in the 70s no problems with brakes but when in a 55 chevy you didnt have any wipers cause there wasnt much vac. to run then constant.dont know much about the one you used but if where me id stayed with the 292. good luck and let us know...
| All times are GMT -8. The time now is 02:01 PM. |
