-   -   4,400 HP ! (https://www.racingjunk.com/forums/showthread.php?t=33136)
TheYellaBrick 02-01-2013 07:20 PM
4,400 HP !
http://blogs.hotrod.com/a-sneak-peek...#axzz2JfSbuTi4
zipper06 02-02-2013 06:26 AM
Now that's weird for me, at first the pics and everything comes up clear then the whole background and pics goes dark, in fact so dark it's hard to see the pics. and impossible to read the print :shock:
fla1976 02-02-2013 08:34 AM
http://i406.photobucket.com/albums/p...pse74c1967.jpg
http://i406.photobucket.com/albums/p...pseb1c5ab2.jpg
http://i406.photobucket.com/albums/p...ps1fabb55c.jpg
http://i406.photobucket.com/albums/p...psc5e863d5.jpg
http://i406.photobucket.com/albums/p...ps19bec999.jpg
Here are some pictures and the text for the engine. There are also links for other sites with the same engine.
http://www.carcraft.com/techarticles...g_block_chevy/
http://www.nitromater.com/nhra/29275...o-mustang.html
http://blogs.hotrod.com/4400-hp-mora...#axzz2JlhfKY1O
It’s highly likely that at this very moment I’m the only member of the media staring at over 100 high-resolution images of what is undeniably the sexiest engine ever created by man. The images are arranged in chronological order, a veritable instruction manual detailing the assembly of a hemi-headed monster that Mother Mopar could never in her wildest dreams imagine. It’s not her fault. Except for a few race cars, Mopars were built for the masses. This masterpiece is altogether different. It was designed to ingest, compress, and explode mass quantities of atmosphere and manmade fuel, creating power to be harnessed and turned into friction, accelerating a racecar to unheard of speeds. Mike Moran’s turbocharged bullet is machined entirely from billets of aluminum and will reportedly build 4,400 hp. How? Stay tuned to Hot Rod Magazine to find out.
TS1955 02-02-2013 09:42 AM
X2
TS1955
Harbone 02-02-2013 02:06 PM
That there is engine porn :!: :wink:
roadkill2 02-02-2013 02:56 PM
I wanna see the Heads!
fla1976 02-02-2013 05:24 PM
Some photos and writeup on the Moran Hemi.
http://bangshift.com/blog/pri-2012-m...nd-turbos.html
roadkill2 02-03-2013 08:25 AM
Still wanna see the heads . . All of the Head(s)!
But as a Machining exercise, it is a work of Art!
On the other hand, there's far cheaper ways of arriving at 4500 HP . .
Jus' sayin' . . .
TheYellaBrick 02-03-2013 10:35 AM
Zip, You couldn't see anything cuz just the THOUGHT of that kinda HP at your beck and call is flat azz overwhelming to the senses ! :D :D
zipper06 02-03-2013 11:38 AM
You're right about that, back in the day when i was going fast (mid 80's) the alcohol funny cars wasn't making anywhere that kind of HP, before the introduction of the screw type blowers, i mean 6.50 at 220 was hauling azz then, now they are running 5.60 at 250 plus.
But on the other hand they are only 500 cu in.
