-   -   1971 Chevelle 383 Stroker 4:11 wheel size help (https://www.racingjunk.com/forums/showthread.php?t=33182)
Ffpm46 02-16-2013 01:20 PM
Hello, I have a 1971 Chevelle 383 Stroker, 2850 stall 4:11 posi rear end. I have Weld draglites front and back 15x8 245/60R15 in rear, 15x4 165R15 in front.
Right now I run 3000 RPM at 50-55 mph, I want to be able to run on the turnpike with my gear, any suggestions as far as tire size, wheel size.
I would Ike to be able to drive 75-80 and be under 3000 RPM.
Is it possible? With my gear setup? Any suggested width, tire and offset sizing?
I would like to do maybe 10" width rear , 7 - 8 width in front.
Any help would be greatly appreciated.
TheYellaBrick 02-16-2013 03:46 PM
Here ya go !
http://www.gearvendors.com/
wazup 02-16-2013 08:35 PM
700r4 overdrive. I dont think you will find the tires to drop the rpm that low. JMO Good luck
Ffpm46 02-17-2013 02:21 AM
That overdrive info is good, but not affordable, just had the 350 rebuilt.
It would be cheaper to drop the gear in the rear end.
A friend suggested that I pose this question. He thought that playing with wheel and tire size would solve my problem.
As I was planning on changing my draglites to something else.
