-   -   jesel belt drive vs comp cam belt 6100 (https://www.racingjunk.com/forums/showthread.php?t=33322)
cujo 03-26-2013 09:50 AM
How good is the 6100 comp cam belt drive compaired to the jesel belt drive . My motor makes about 830 hp.
zipper06 03-26-2013 03:50 PM
The Jessel belt is much better, i havs a Comp cam 6100 on my 434" and the problem with them is they only have 3 screws to hold the drive to the cam hub on the large gear, and on the one i have it stripped the hole out with the splined screw. I had a Jessel and sold it because i had already installed the Comp unit (hind sight is 202/20) the Jessel had 4 screws and larger dia. i know it cost more but the value is there.
cujo 03-27-2013 03:32 AM
Thanks
