-   -   Headers and Steering Shaft problem. (https://www.racingjunk.com/forums/showthread.php?t=33571)
jreiley 06-25-2013 11:37 AM
This may not be the right place to ask this but I need an answer. I have a 3rd gen camaro that be put a big block in. When I bought the car I was told the headers that came with the car would clear the steering shaft. Well it doesn't. I can't afford 1500 Lemon's headers to resolve it. Is there any other way without spending big bucks to clear the headers?
TheRabbit 06-25-2013 01:49 PM
I'm sure somebody with some camaro experience will post soon, but this is what I used on my truck.
http://i163.photobucket.com/albums/t...8/Steering.jpg
fast75vega 06-25-2013 05:32 PM
Re: Headers and Steering Shaft problem.
how about some pics of what your working with
outlaw256 06-26-2013 03:48 AM
make your own. it aint all that hard to do....
markdunlap 06-26-2013 02:25 PM
Headers
How many tubes interfere?
I put a BBC in a Chevette and used Camaro headers, only modifying 2 tubes. Just bought a couple U-Bends and cut out what I needed. I fitted it, tacked it together and then had a good Tig welder finish it up for me.
roadkill2 06-28-2013 07:06 AM
Probably the easiest is to install a Vega steering box. That's the usual way around all this . . .
Scooterz 06-28-2013 04:09 PM
Be careful if you plan to modify existing headers. Carefully check all the other gremlins too (plug clearance, height/ pan clearance, steering box, filter area, etc...) before you commit to alter them much... in case you get too invested in something you may not end up liking. Are they nice headers?
jreiley 06-29-2013 07:16 AM
The headers are ok. I got them with the car. They have been coated so they look ok. There is absolutly no room to fab a new tube for the front header. The cage extends all the way to the front of the chassis. The steering shaft rubs against the headers and makes it impossible to turn the wheel. I was thinking about turning down the steering shaft on a lathe.
TheYellaBrick 06-29-2013 09:29 AM
NO NO NO NO NO !
NEVER compromise safety and especially in your steering hardware ! Reroute the shaft or do some else . NEVER reduce the size of your shaft !
:shock:
fast75vega 06-30-2013 10:59 AM
Originally Posted by TheYellaBrick
NO NO NO NO NO !
:shock:
i was thinking the same thing....! pics will really help us to see what layout and come up with safe ideas .... just sayin :wink:
